turbofiat124
- Mar 23, 2011
- 288
So I've got two Snapper 33" riding mowers. I think I can make a running mower out of both of these. Take the good parts off each and combine them.
The major hurdle is fixing the trans-axle on at least one of them. Everything else is straight forward.
One is a 1979 model:
It's missing the deck (which I transplanted to a 2001 Snapper and later sold it)
8 hp Tecumseh engine (no balls), original 12 hp B&S engine ran out of oil and seized.
rear end is locked up (maybe broken chain?) but can be shifted
rear wheels are missing (used them on my daughter's 110cc ATV)
The 2000 model:
Transmission is locked up in 3rd gear but will move otherwise
Steering "triangle" broken and I welded it back but front end alignment is messed up
Front tires won't hold air (no big deal, they make tubes).
The plan:
Use the frame from the 79 model
See if the chain is broken in the transaxle (maybe an easy fix)
Use the 15 HP Kohler engine, deck, rear wheels from the 2000 model.
OK here's the question. I've looked on Craigslist and it seems most people want anywhere from $200 to $300 for use Snappers. I seriously doubt if I put my time into putting these two mowers together to make a running mower, it be worth my time for $200. I have more important pending projects to take care of.
I actually like rear end Snappers versus front engine tractor type lawnmowers. Snappers Hi-Vacs have excellent traction going up hills, more comfortable riding position because you don't have to straddle the front end, easier to maneuver and see around shrubs and bushes. So I guess if I got this thing running again, it would be used as a "3rd" backup riding mower.
The bad thing is by the year 2000, the build quality with Snappers was horrible. Paper thin decks (bottom lip wears off), front wheels made from stamped sheet metal (that cracks and sheer off at the hub), etc.
That's why I bought a Husqvarna riding mower instead of another Snapper about 7 years ago.
So should I combine these mowers together or sell the deck, engine and wheels? What would you guys do?
The 2000 model:
The plan:
