Really isn't any adj on it, are you getting a ground from the switch to the block? that is what shuts it off, and service manual if avail won't show anything for the engine mower only. if the switch is closing make sure the wire coming off of it is good, check from the coil to the switch for continuity also, isn't much to it.
