smooth start
proof set
I have a 5 yr. old snapper rear engine rider that I changed the rubber drive disc on because it didn't want to pull hills. The disc that I put on had the liner in it like the old one and I changed the flat washer type disc also. Every things turns free with clutch depressed like I think it should but it will jerk a knot in your neck when you let clutch out. It no longer has a smooth start clutch what did I do wrong?
