I run 2 Stihl 009s daily. Both saws have over 1000 hours and 120 psi compression. Saw A began smoking(a lot) but continues to run fine with no change in compression. I drained the bar oil tank and swapped carburetors between the two saws, saw A continues to smoke, saw B is unchanged. Same gas in both. What has happened?
