Small tweak needed for my 11hp Tecumseh snow blower carb.
svejkovat
  • / Small tweak needed for my 11hp Tecumseh snow blower carb.
OH318EA-222712 11 HP
Replacement engine on a Toro 724 Snowblower. Year old post here discussed the need to clean the carb and adjust a tad richer. Was hunting badly. Disassembly, cleaning, and tiny adjustments did the trick nicely and it performs beyond my expectations, however... under maximum load - deep heavy snow - for about 30 seconds it will sputter and hick-up a bit.
That's the only glitch at all. Starts easily, runs smoothly, works like a champ. Only under maximum load for about 20 feet it starts to sputter a bit. Continuing on it will eventually die.
Indication of lean/rich? Air flow? Air sealing?
Thanks.
