slow moving
451johnny
I recently got used kabota B7001 don't know much about them ..I changed the fuel and air and in doing so the tractor wouldn't start then I found out that I had to bleed the line in order to start it but now that I got it going the tractor move very slowly when I put it on 3nd gear it moves like its on 1nd gear..does bleeding the lines affect the speed of the tractor..?? thanks in advance johnny
If that tractor has a high and low transmission, check to see if it is in low. I have only used tractors so that is all the help I can give. Others will chime in soon.
well it sure sound like that might be the problem ..so now im going to have to check on that..I will let you know soon thanks so much...johnny
