Model 1692454
20 hp Kohler Command
replaced fuel & air filters
oil level full and clean
no gas in oil
starts with no hesitation then stalls within 4 seconds. Every time.
Model 1692454
no gas in oil
Lawn Tractor Manuals | Riding Mower Manual | Simplicity Mowers Manual shows 20 h.p. being B&S Vanguard & 18 h.p. Kohler Command. Either way you need to adjust valves to specs. Post all numbers from engine. Check neutral detent w/safety start switch.
Model 1692454
no gas in oil
Found that fuel solenoid isonly energized during cranking. Is not energized in run position of ignition switch. Safety switches all made and energized. Don't know where to look.
Spark plugs fine.
Put jumper from positive battery to fuel solenoid.
Now it stays running when ignition switch released from start to run position. Will put toggle switch in jumper so battery does not drain when not being run.
At least I can mow untul I find root cause.
