Simplicity Regent
sos1
Just joined. Have a problem removing the grease fittings on the mower deck. The fitting bases turn
but will not back out. I would prefer not to cut them out and possibly leave part of the fitting inside the
arbor. Any solutions other than drilling and tapping new holes for new fittings?
Thanks in advance for your comments.
SOS1
chance123
Not familiar with your machine, but I remember somewhere on the old toros there was a grease zerk that was of the pressed in type. It might have been on top of the pulley above the self propell transmission to pump lube into the trans
txzrider
are you sure it was not just over tightened and possibly has stripped threads? usually if you take a pocket knife blad and wedge it between the spindle and the zerk while you uncrew it.. it may come out.
