Simplicity courierZero turn transmission question.
RCRVRP
Bought a used mower and it works fine but I want to change the transmission oil. Is there a grain plug on it? I didn't see on but just glanced under it. If not is there a bolt one could take out to drain it? And then is there a fill spot? Thanks, rcrvrp
Hopefully you mean "drain plug" instead of "grain plug" because there is no such thing as grain plug on a transaxle.
But we still need the real model number from the serial number tag to lookup the mower to even see what you have.
