Simplicity 12 LTG
daithio
Hi Folks,
I own an 1989 Simplicity 12LTG with turbo collector. My problem is that the battery never seems to charge. I had to short out the pins under the seat to bypass the sensor as I had issues with the mower cutting out. Could this be related to my problem ?
Thanks in advance, Dave
Briana
Hey there - WELCOME to LMF!
I moved your thread to the Simplicity Forum. :smile:
benski
Yes, it very well could. You might want to spend the money for a new switch and see if that fixes your drain problem.
