Silverpro Dura Force 6.5 hp - shuts off after a couple of minutes
Rmhindley
My Silverpro Dura Force mower will start but shuts off after a few minutes. Looks like it runs out of fuel. After a minute or so it will start but does the same thing. I changed the coil and sparkplug, and cleaned the carburator. Any suggestions?
Hello,
Check your gas cap vent too,,,sounds like it may be plugged
Regards
Jeff
These motors (that I've seen) have a rubber like float seat. The original rubber doesn't seem to like today's gas and swells up a bit, lowers the fuel level and restricts the flow into the carb. See replacements on -thatauctionsite- for a couple dollars. Might take the carb off, remove bowl, turn it up side down and see if the float sits mostly level as it should.
