Tennjaguar
- Oct 15, 2025
- 1
- 1
Hi, I could use some help with my 2013 Grasshopper 725DT6. I think that I may have two problems but I’m unsure. It seems everything works when cold, then after warm up my blades stop running and will not reengage. I can’t hear the clutch engaging. Also the ignition switch will not shut down the unit. I need to manually shut it off. I have cleaned the fuse block and changed the fuses. I have checked power to the clutch and I have 12 volts there and it will light up a test light. The clutch ohms out to 2.2 Ohms. I opened the control panel and checked wiring in there and don’t see anything wrong. I’ve pulled on the wires to see if I had any bad connections. I replaced the ignition switch a few months earlier and replaced the PTO switch last year. The wire diagram that I’ve been using has a unit called the “Stop solenoid module” that I can’t find anywhere that I have looked. I have a circuit board with two resistors and about a dozen wires soldered to it. Any help would be appreciated.
