should i replace fluid in transaxle?
logert gogert
hey, its me.......again (*sigh*).
since i cant sell that hydro mower, i was just going to keep it and use it to haul stuff around, pull my mowing equipment ect.
but its whining alot, and i decided to come here and ask yall if i should replace the fluid in the transaxle.
thank for any help.
Scrubcadet10
Moderator
Staff member
Your question is answered in your other thread
Darryl G
If it's whinning badly the damage is already done. With that said, you would need to remove the transaxle to change the fluid. Doing so may prolong its life by removing any abrasive wear debris, but it's not going to "fix" it.
Hammermechanicman
The whining is fluid bypassing the pump pistons. Put some 20W-50 in it and hope for the best. The pistons and pump are already starting to score. Thicker fluid may help. If it is a K46 that is called fhe whine of death.
mechanic mark
post complete model & serial numbers from tractor & make
logert gogert
model number: ( under seat )
13CO6166190
might be an O, or an zero couldnt tell
family: ( on engine )
YBSXS.7452VR and about an inch next to that it said: 275103
serial number: ( under seat )
1E202H20297
