I just bought a shingu bell cutter super 250 weed whacker in a flea market. It looked like it hadn't been used much and had lots of compression, so being only $5.00 i bought it. When i got it home i noticed some of the black rubber tubing in the tank had melted, it was a black goo. I put some gas in it to try to wash it out, but poked a hole in the tank and ruined it. I took the plug out and put some gas in the hole and it fired right up so i guess it's worth fixing.The question is, is the brand of weed wacker good quality. and where can i get parts for it. Also will a tank off another brand fit on it.
