Hello,
I have a Shindawa T-27 String Trimmer. The trimmer will only run for a few seconds if I put a little gas directly into the carb, then die. So I know it has compression and spark. I took apart the carb and replaced a torn diaphragm and the overflow valve that had the rubber tip torn. Although the other gaskets looked good, I replaced them all since they were in the kit however the trimmer still wont run on it's own, only for a few seconds with gas poured directly into the carb.
Any suggestions on what else I should look for?
Thanks!
Thanks!
