shifter cable cant go forward
speedy 1
Hi
I have a craftsman snow blower model number 944524410
the motor model number is 20M307
The problem I am having is the shifter cable is slipping and
I can only go in revers I cant go forward at all
I am looking for the installation picture or blue print
on how to repair it or replace the cable or any info that will solve
problem .
thank you
Tip the unit on it’s nose and remove the bottom panel. This will allow you to see what parts a moving and those that are not. My guess is that your drive wheel is extremely worn and no longer making contact with the drive disc. This manual may be of some help. https://usermanual.wiki/Craftsman/944524410.783536940
speedy 1
Hi
thank you for your answer
I when under the snow blower tonight under the control panel
I have lost the small pin with the counter pin that holds the cables together
and all my cables are in the air
would you have a picture or blue print of the under control pan
the drive cable is were my problem
thank you
Did you look at the parts manual I enclosed?
speedy 1
Hi
thank you for your answer my problem is the under the control panel
the right side the speed cable came out of position from its place
I would need help putting it back and a picture and info to change the
plastic panel its broken
please see pics
thank you
nbpt100
Some time has past. Did you resolve this? Did you have to replace the console?
