L LEveritt Forum Newbie Joined Oct 20, 2026 Messages 2 Oct 20, 2026 #1 Need to replace shelves on 721DT GH. SERIAL 6417527
B Bertrrr Well-Known Member Community Leader Joined Mar 11, 2021 Messages 656 Oct 21, 2026 #2 Shelves ? or Sheeves ? is there a question here ?
ILENGINE Lawn Royalty Community Leader Joined May 6, 2010 Messages 12,020 Oct 21, 2026 #3 I moved the thread to Grasshopper so it will be seen by more members.
L LEveritt Forum Newbie Joined Oct 20, 2026 Messages 2 Oct 21, 2026 #4 Bertrrr said: Shelves ? or Sheeves ? is there a question here ? Click to expand... Yeah shelves on my GH. DOES YOURS HAVE ANY?
StarTech Lawn Royalty Community Leader Joined Feb 19, 2020 Messages 14,522 Location Pluto Oct 21, 2026 #5 IF your are referring the 415650 on the power shaft. Mostly you going needed to remove any retaining hardware. Then using a puller and lots of heat pull the cast iron pulley off. Also it might require heating the new pulley to install it.
