mechanic mark
- Jul 15, 2013
- 176
- 7,495
My son & I spent several hours the past two Saturdays servicing our Tuff Torque K664, KXH10. & K57 transaxles. We ordered the gear oil 5w-50 & filter from Tuff Torque. The K664 transaxle uses a cartridge filter up front at six o'clock position & a spin on filter inside right rear fender. Simplicity Conquest 4x4 tractor with power steering & 50 in. mower deck uses 5.4 liters of gear oil. Everything went well & glad we decided to perform maintenance as old gear oil & filters were original, 117 hrs. on tractor. The K57 transaxle is on my 2010 Simplicity Broadmoor & uses 2.2 liters of gear oil. This was first service with 422 hrs. on tractor. We used jack stands under both tractors for Safety. The K664 & KXH10 both have drain bolts as well as a resevoir & service plugs topside. The K57 does not have a drain plug so we just rotated it, wheels on unit, upside down after removing service plug & magnet. The K57 was caked in mud & dirt so hosed it down first thing before servicing. Drove both units around block minus decks & performed exceptionally well. Just thought I'd pass this information along to those of you who have wanted to change transaxle gear oil & clean aluminum housings but have hesitated to do so because manufacturer or dealer has stated non serviceable sealed unit.
