Service warning
annelise
I have a Ferris zero -turn riding mower, IS3000Z. On the left hand side, near the choke, is a display area called Ferris Hours where the number of hours mowed is normally displayed. Today, instead of hours I found three separate, hard to read, communications, the last being "8.8" with SVC under it. I can find nothing about this display in my operator's manual. Has anyone run into this? Mower seems to run fine but I do want to keep track of the hours. Mower is serviced once a year, about a month ago, and additionally when there is a need.
Hi annelise
Welcome aboard to lmf and there is a lot of knowledgeable people on here to help solve your problems and maybe you can solve someone elses problem someday to. What is the brand of engine you are having trouble with on that hour meter , maybe if you go to made your engine on the internet there will be a answer to your question there?:licking::licking:
