Service question
Eli 77
hi guys could use some help just got a grasshopper 725 g2 gas engine no manual came with it just wondering what weight engine oil to run in it and synthetic or conventional and is the hydraulic oil for the drive pumps need to be grasshopper fluid or will other do and when changeing the hyd oil for the drive pumps just a drain and new filter type job or is there more to it Thanks
MRCo.
DO NOT guess the hydro oil! Use the wrong stuff and you can fry the motors. Have you googled this or checked he Grasshopper site?
