Service Manual Cub Cadet SZ60
Zabowka
Has anyone with a Cub Cadet SZ60 Commercial Tank , with a steering wheel been able to find a provider for a service /repair manual? Would like to get some directions for replacing the filter and fluid in the drive units, as well as issue with the electronic steering not working.
Auto Doc's
First, what is the product label numbers on your machine. It should be under the seat. They made a variety of this model.
Cub Cadet.com should show whatever manuals you need for this unit.
Part Tree will have exploded views of most of the major components on the machine.
Electric steering?
These usually have mechanical levers that run from the front steering to control the power variance on the drive motors at the rear. Steering is controlled by the motors. The front wheels have a half-moon cog gear system that work in conjunction with the steering wheel shaft.
What is the steering doing or not doing? Binding or hanging up once in a while?
sgkent
yes, I just Googled it and came up with both operator and service manuals in the first page that came up. You'll need the exact model number and serial number to pick one out.
