Sears standard shif
Pkaram
Mower will not get into gear.. Friend was using and stopped moving Belt is not broken. Could a link be broken or loose?
Thanks
Philip
Boobala
The folks here need a bit more INFORMATION ..... they make a wee bit more mowers than Craftsman, ...year , model , serial number , engine , type , model , etc. etc. YOU need to help us before we can help you !
all this infomation is normally found right on the machine ....do the best you can ......... Boobala also ... WELCOME !! :welcome:
