Sears Fuse Amp Rating
They are 20A but use a good quality fuse from a parts store. "White label" cheap bulk fuses are not reliable.
If you keep blowing a fuse when hot that is an early sign of the PTO clutch failing.
The most common problem that "pops" a fuse is jump starting off of a vehicle battery. The inrush of high Amperage from a vehicle battery will "pop" a fuse.
Thanks...this particular model has a mechanical belt tightening system...no electric clutch. 20Amp is a good recommendation!!
Thanks,
bartles
A 20A main power fuse is standard for most models regardless of options.
