I bought a 1999 LT155 last weekend and have been slowly going through it as time permits. I have no idea how many hours are on the Kohler motor, but everything appears to have been well taken care of. So far I've aired down the tires from 16 psi to something more acceptable around 7 or 8 psi. Greased the deck spindles 3 times (I thought I heard a slight squeal down there) and it has quieted down considerable.
Today I took the air cleaner off and started it as normal with just a bit of choke. I let the engine warm up for about 5 minutes and then started pouring Seafoam in at about a tablespoon or so at a time while the throttle was at 1/2 throttle. The engine would start to sputter so I would stop while it caught up. Each time there was a decent puff of smokey vapor from the exhaust. I did this probably 6 times or so. When I did it the last time I shut the engine off while it was still sputtering. I left it alone for about 45 minutes or so and went back out to fire it up. There was plenty of smoke from the exhaust for about 5 minutes or so while I ran it wide open. When the smoke had pretty much cleared up I shut it off. This evening I dumped about 3 oz in the gas tank and went out to mow. The power is much smoother and I can now start it without the choke. I am pleased at the results.
I've used Seafoam in the fuel on my boat, motorcycle, and cars with never a problem. So I thought I would try it in a small engine. I didn't see a thread on Seafoam so thought I'd share. I've also heard good things from Marvel Mystery Oil, but have never tried it.
