wont run if release break or engage deck. Help
C chicagorick Forum Newbie Joined May 21, 2012 Threads 1 Messages 2 May 21, 2012 / scotts 1642H #1 wont run if release break or engage deck. Help
D declid Forum Newbie Joined Mar 9, 2012 Threads 1 Messages 7 May 21, 2012 / scotts 1642H #2 check the seat switch connection
C chicagorick Forum Newbie Joined May 21, 2012 Threads 1 Messages 2 May 21, 2012 / scotts 1642H #3 I tried opening the circuit at the seat as well as jumping the circuit (I believe it needs to be open to run). still cut out whne either brake is release or pto is engaged.
D declid Forum Newbie Joined Mar 9, 2012 Threads 1 Messages 7 May 23, 2012 / scotts 1642H #4 check for broken ground wire, or bad connections, did u test the seat switch with a omh meter to see if its workin,, tom
