Hi Guys,
This is my first post, so tks in advance. I am a retired medical person -- so equipment repair is not an everyday endeavor. But since I have more time -- I decided to learn how to repair what I paid someone else to do for me before retirement.
I am working on a old Scott 1642 -- its about 12 yrs old and I was going to take to scrap yard and decided to see if I could get to work again. When it died several yrs ago -- It failed start after I had turned it off. At the time I felt it was ignition key problem and since was old I just bought a new mower and parked the old one.
I started off by changing the ignition key, new oil, new spark plug and fogged the cylinder, cleaned gas tank and attempted to clean the carburetor. It had a solenoid on the bowl and this turned out to be bad and the inside was more corroded than I thought should be and it kept filling with gas -- so I replaced the whole carburetor. It still would not turn over so I hot wired across the solenoid and was able to to get started. I attempted to figure out a way to take out the old solenoid -- it is locate just in front and behind the right rear wheel. I really don't know how to get this out short of cutting the two screws with a hacksaw --- even that way it would be very difficult -- it is a very tight space. Has anyone had this problem before and how was it solved? Tks
