Scag Turf Tiger will not start. Check engine light stays on
bikerboy
  • / Scag Turf Tiger will not start. Check engine light stays on
Cleaned battery terminals and charged battery.
Hear a noise from the right side of motor. Not sure if that is a voltage regulator or not.
Where do I start?
Thanks
Mad Mackie
If your Turf Tiger is still on warranty, go to your dealer.
Next, read your operators manual.
If you would like for any of us to assist you in any way, you need to tell us your machine model and serial number as there are several hundred Turf Tiger versions.
mechanic mark
bikerboy
[QUOOE=Mad Mackie;239264]If your Turf Tiger is still on warranty, go to your dealer.
If you would like for any of us to assist you in any way, you need to tell us your machine model and serial number as there are several hundred Turf Tiger versions.[/QUOTE]
Ok I apologize for the lack of information on my scag.
I believe it's a 2003 or 2004 unit.
Model SMT 61A
Serial 945 1351
Engine Kawasaki FD 791D 29.0
It has 1175 Hrs on the mower.
The ck engine light stays on.
So far all I have been able to do is ck the brake relay and the seat relay.
I'm not sure where everything else is.
I do have a manual with the wiring diagram.
Thanks for all help.
