Ron Jepsen
- May 7, 2019
- 2
- 4
Hello all
Got a problem with my Scag Turf Tiger. It will not turn over/start unless I have a battery charger
connected. I have replaced the Battery with a new one (CCA 350) and it is fully charged. I've cleaned
all of the connections. It will not turn over unless I connect a battery Charger/starter then it will start
and run fine. With the charger connected I will turn the key to Start position and after 2 to 3 seconds it
will crank and start fine. I'm thinking dirty contacts on the relay (the small one in the console)? I'm still checking other stuff.
Any helpful suggestions would be greatly appreciated.
