Scag turf tiger steering problem.
scagy
I have a 2002 Turf tiger with a 27 hp kawasaki model SST72A-27KA, serial #7750414. I believe pumps and wheel motors are original. The steering works fine when going forward, both left and right have equal travel and power. When going into reverse the right steering lever must be full aft in order to get any reverse control, and then it is not very strong. I would like to know if their is an adjustment that can be made to correct the situation? If no adjustment, what component should I look at first as the primary cause of this problem? Is their a systematic way to trouble shoot this problem?
Thanks
How do you go about testing the hydraulic pump and or the wheel motor. I suspect one may be really tired, and is it economical to have them rebuilt?
If I need to purchase new or rebuilt, any recommendations for source?
Thanks
