scag TT II Kawasaki engine FD851D fuel pump problems
Maxgigo11
Hi, I hope someone can help me out. I have a 2016 Scag turf tiger II with the Kawasaki engine. I thought I had a faulty fuel pump, it wouldn’t come on for the 3 secs after turning the key switch, so I purchased a new pump. I have the same problem. I connected both pump directly to a 12v source and they worked fine. I took a voltage reading on the leads to the pump (disconnected from the pump), and they read the proper 13.5 Volts when I turned the key, but once connected at the pump, it drops to zero. I’m not sure why I get this voltage drop. I really wish I could find the electrical wiring schematic. Does anyone have any ideas?
Truly appreciate any help
