Export thread
scag tiger cub
#1
B
billingsted
I have a tiger cub that just stopped cranking. I heard the starter relay crying so I replaced it but it did'nt help. There is no voltage on the solinoid switch wire. what's up?
#2
D
Dinga
Might want to try the relay at the ignition switch.
#3
S
ScagManDan
I've had the same issues with several scags before. It typically is not the solenoids. Try replacing your regulator first. If that doesnt fix it try a new battery. Sometimes the batteries blow cell walls out from so much beating around and yet they can still test good they wont function properly. What motor do you have?
