Scag Tiger Cub right lever very weak when hot
closecut
I recently bought a used Scag Tiger Cub,and it runs good till it gets hot,then the right lever feels rough and does not respond well to movement.It has a rough spot in that lever even when not running,sitting still.Linkage seems to be in good shape.
Oil was changed after I first got it.Used recommended oil.Could the problem be in the hydraulic motor itself?
Is the pump rebuildable?The repair kits I find on line are merely seals and gaskets.Is this all there is to rebuild a pump?
Thanks is advance for all help on this matter.
