hey everyone, new here. Been having some major troubles lately with a 2002 Scag Tiger Cub with the cv-20 Kohler engine. Before I go any further, let me mention that the engine has been apart, ring replaced, gaskets ect... The reason I took it apart was because the spark plug on the right side would always foul, and it burned through a quart of oil every couple hours. I also discovered a bunch of gasoline in the crank case when I took it apart, but I believe that this was due to the choke sticking. This engine has been run low on oil in the past and I think that has contributed to the ring damage...anyways, onto the current issue. Since getting the engine back together and back in the mower, whenever its started, it runs good for about 30 seconds, then starts blowing smoke like crazy. Enough to kill all the mosquitoes for miles around. In fact, its so bad you would probably die from smoke inhalation if you tried to mow with it..seriously. My question is, what else should I try to be able to fix this. I want to do a leak down test to determine if one of the heads is bad, or if the block is cracked. I cant imagine it being the rings because I just replaced them. And the oil level is about half way on the dip stick.
thanks, Eric
thanks, Eric
