2008 Tiger Cub, 48" Velocity deck, original engine was a 26 HP Briggs ELS. The 26 Briggs ELS had low compression in the #1 (L/H) cylinder due to stuck piston rings. Although is was still running but sneezing at idle, at 473 hours, I replaced it with a new 30 HP Briggs Commercial Turf Cyclonic filter engine with an oil cooler. Machine total time is 651 hours, new engine time is 178 hours switched to full synthetic engine oil at 100 hours. Collection system has been on for most of the machine time, 3rd set of blower bearings, 2nd blower fan, 2nd hose from blower to bag housing, new pump drive belt and drive pulleys at 400 hours, 2nd deck V belt, 3rd hourmeter. Same old man operates it!!!
Mad Mackie in CT:laughing::biggrin::smile:
5W-30 full synthetic in the engine, switched it at 100 hours.
20W-50 Dino oil in the hydraulic system.
Which brand of synthetic do you use?
Also, what made you decide on using the briggs cyclonic as opposed to going with a kawasaki engine?
Is the main reason you chose the briggs is just because of price,or were you actually impressed with the briggs cyclonic technology,and quality of build?
Where did you source the Briggs from? That's a great price for such a decent motor.
I am loving my new suspension seat, much easier on my lower back on bumpy lawns. I should have done this a long time ago.
Still need to mount a new tool pouch to the rear of the seat back, probably will need to sew some Velcro onto the pouch and put the sticky Velcro on the seat.
I should have done my leaves earlier today before the rain came. But tomorrows winds will redistribute them anyway!!!
Nice tractor, but for leaves I perfer the Scag.
How does the plow work out on snow? Can it push the heavy stuff at the mouth of the driveway?
