Scag STMH 23CV - 9220061 _ Sundstrand Pump
Jer05
I use a Scag STMH 61" to cut 2 acres and it is a great machine.
I have been losing hydrostatic power. It work good in reverse but not so great in forward. I have checked the mechanical adjustments and that is good so looks like the pump and or wheel drives are now 'tired'. Otherwise, deck, engine etc all in great condition so would like to repair.
The main drive pump is Sundstrand Scag Part No: 481100
Does anyone know:
1. Which series/size Sundstrand pump this is - they seem to go by 'series'?
2. Is an overhaul kit available?
3. Has anyone rebuilt the sundstand pump and wheen pumps - how tricky and what was the result?
4. Is there an alternative aftermarket pump that is good and will fit?
Feedback appreciated.
Regards
Jer
BlazNT
Before you go all postal on the pump try replacing the drive belt. It is much more likely to be the belt over the pump.
Jer05
BlazNT
You have made me think and I will check that again in terms of the pulley alignment and belt condition. Have you lost pump power/hill climb ability with a tired belt?
Regards
Jer
BlazNT
Yep about 3 weeks ago. Replaced belt and good as new.
BlazNT
It looked just like the new one except the V part was smaller buy just a little. I woild have never thought that would cause so much trouble.
Jer05
Thanks for the update - helpful
Jer05
BlazNT
The best part about changing the belt first is that even if you need to fix the pump after this the belt needed to be changed. So no loss starting here first.
