Scag Serial Number
SmallTexasFarm
Hoping there's a solution to this, but we bought a used 72" wide Scag back in 2021 and I'm trying to figure out the serial number. I see where the serial number sticker is (between the seat and the controls) but it's totally worn away and just a silver sticker. It was back then also so the bill of sale we just put n/a. The mower only had 500 hours on it when we picked it up but it was used commercially to mow SpaceX up in McGregor, TX.
Is there anywhere else that it would be located on the mower? I'm thinking stamped into the block, like on cars? It's a hail mary thought but most parts sites use the serial so without it, it's a pain.
Thanks in advance.
Best advice I can give you is to take the engine numbers to a Scag dealer and see if they can back check which models use that engine. Or contact Scag directly.
