SCAG Magnum lll (The Beast)
neighborbill
I recently obtained a Scag Magnum lll through a swap. Now I'm burdened with how the heck to get to all the filters and fluid changes. This thing is a real beast. I found all the fitting to be greased and now what to change oil, diesel filter and hydraulic fluid with filter. Does anyone have any experience with these machines to find out the best way or anyway to get at the things that I just mentioned.
I believe I'm going to have to jack it up from both sides evenly and put car stands underneath it. First time I tried the thing wobbled. The center of gravity is right under the two monster tires. I think that if I get it high enough I can use more card stands to support the rear tire and the cutters in front.
Not very many of these things around but man are they ever built like tanks.
Bill
