Scag Freedom Z SFZ52-24KT electrical issue
windyridgefarm
I have a Scag SFZ52 that does nothing when trying to start. Used yesterday. Will start when I jump across solenoid (seat sensor unplugged) but when I take brake off, move a steering lever or engage pto it quits. Checked 20 amp fuses. Have read about the green wire from switch to solenoid. Any help is appreciated.
Update: After plugging seat back in could use mower. Just have to now jump start to start with brake on. But still won't start with switch. Can I jump the 3 start positions on the cable to the switch together to see if it will start? this should determine wiring or switch?
