Clayton_ray07
- May 4, 2017
- 1
- 5
Mower has been running fine, cranked this morning then 20 minutes later wouldn't do anything. Turned the key moved the left arm out then back in and started right up. Stopped it to take cover off and male sure dirt wasn't behind arm switch. Went to crank back up and it'll turn over but not fire up. Checked solenoid with test light, works like it should. Checked all wiring connections and they are good. Put test light on spark plug wires turned key and nothing, so I'm thinking maybe the coils.
I tried starter fluid before everything to make sure it wasn't a gas issue.
