i have a Scag turf tiger that dies when i engage the blades What could the problem be?
D DubSabrsula Forum Newbie Joined Jul 10, 2018 Threads 1 Messages 1 Jul 10, 2018 / Scag Dies when blades are engaged #1 i have a Scag turf tiger that dies when i engage the blades What could the problem be?
BlazNT Lawn Pro Joined Apr 26, 2012 Threads 28 Messages 6,973 Jul 11, 2018 / Scag Dies when blades are engaged #2 First, explain how it dies. Like you turned off the key or sputters then dies. If it is like you turned off the key then most likely it is a safety switch. If it sputters the dies it is most likely a dirty carb.
