tigercat
- Nov 17, 2012
- 19
- 280
Hello everyone, new guy here.
I have a Scag Tiger Cat with the 3 bagger grass catcher. It has the Kawasaki engine. It's a new machine that is used for homeowner use. It seems the air cleaner is in a poor spot when running the bagger. It is quite dusty and I figure the air cleaner will need to be replaced often.
I was thinking of adding a pre-air cleaner around the air intake to repel some of the dust (i.e. a Briggs & Stratton green foam type filter, or maybe a tee shirt could work also. I could use a nylon zip tie and secure it on, then tuck the bottom of the filter underneath). I figure this would save the air filters somewhat from early replacements.
So what are your thoughts on adding a pre-filter over the air intake? You think this might be a bad idea?
Thanks.
Thanks.
