Safety Switch Problem Too
Ciscoborb
I have a Z248F. After I start it up and move the levers in from the Park position the left arm being moved in causes it to shut off. I know that moving them both in simultaneously is what you have to do but I did notice that it’s the left arm by moving it in and out it reengages when moved out.
Ciscoborb
So I tried again. Start up and when I disengage the right lever it still runs. I disengage the left lever and it shuts off.
