I have a quick question regarding safeties in sub-freezing weather. I have an OLD snapper LT125 - that I recently upgraded the pulse fuel pump to an electric fuel pump (and it runs SOOO much better now!!)
I typically use this mower as an ATV (with a pull-behind cart) to move equipment and tools across muddy fields - to remove the risk of getting my work truck stuck in those fields. This morning - we were at 13 deg. F. - and I went out to start the mower to put it on my trailer - ran it for 5-10 minutes - and once I released the brake pedal lock, (or eased up on the brake pedal) - the mower would die.
At first I though it was just not warmed up - but after several times of this - I realized it MAY be the safety interlock circuit not allowing it to stay running once the brake was let off. IS there a possibility of one of the interlock switches being frozen in position (either closed or open) and killing the ignition when I try to release the brake? I don't have a spot indoors to warm up the mower to above freezing temps - to see if it just needs to unfreeze a switch.... So was wondering which interlock might be the culprit. (I'll likely jumper the seat switch.... where are the others?)
I DO have a wiring diagram - and on there see the seat switch... what other interlocks are there for me to check? Diagram shows a "Pedal Switch" as well as a
"Reverse Pedal Switch" - are those going to be under the chassis/pedals? If not a switch frozen - maybe a squirrel or rat has chewed a wire or something....
Thanks,
Rex S.
Thanks,
Rex S.
