Sabre Tooth Tiger Gas Engine Probelm
jimmytruth
New to the forum, y'all got the info!!
Hit a branch it pulled my gas line off. I put line back, but there's what looks like a drain line metal fitting above where the fuel line goes into carb that has gas coming out of it. Any clue what that is or if there was a hose on it. I can't find a picture of the setup, to tell if there should be something over that fitting.
Help!
Jimmy
