sabre lawn tractor
harleyman93
i get fire from starter to selanoid but not to plug why can't i get it to fire and start:frown:
Let me get this straight. Your engine will turn over, but will not start. You have checked for spark at the plugs and get nothing. If that is true then I have a couple of questions. How are you checking for spark? What are your engine numbers? What is your mechanical background? When you post back, we will be able to point you in the right direction. Finally, have a little patience.
