Need to remove the ignition switch. I Removed three "obvious" bolts, but can't see what is still holding the plastic cover. Also looked up from bottom side, but was unable to squeeze the two tabs on the switch enough to remove it from the top side. Maybe if I remove the mower deck this would allow more room on the bottom side to maneuver.
