Howdy all. Recently picked up these 2 mowers to repair and flip :biggrin: The 50 had the left hydro removed and partially disassembled, the 42 has a blown 17hp Briggs. So I checked Cub Cadets and this is what I determined. First here's the model numbers RZT 50 17BA5A7P712. RZT 42 17BA5A4G709
According to Cub's parts website the RZT 50 left hydro part number is 759-04144. The RZT 42 left hydro is part number 759-14142. All the same except the last digit. Next I checked the left side Hydro Gear part numbers that are on the tags on each mower. Which are both the same ZA-DFBB-3D7C-2DEB. Hmm. Very interesting. So I'm thinking that the hydros are interchangeable according to Hydro Gear but not Cub because of the different part numbers. Anybody know the difference or if this can be done? Thanks again
#2
BlazNT
Check that all the connections on the outside are the same. If they are you are golden.
