RZ4219 Belt Issue
lunar
Product # is 966809001
I picked this up second hand and it seems to run well. I believe it takes a 1/2" 118" belt. However I put a 118 1/4" belt and it seems too lose. It spun the blade for a bit but after cutting for about 3-5 minutes the blades seem to stop when hitting grass. There is a little slack in it so thats probably my issue. Is there a good way to adjust this or should I get a smaller belt?
P.S. Didn't come with a shroud for the pulleys so I'm going to see if I can find one.
581805901 1/2 x 117.3
might consider 1/2 x 117 due to pulley wear.
