Ryobi RM480
kd0gd
I've replaced the batteries and the motor control box on my Ryobi RM480 and after reassembling the meter does not light up when I turn the switch to the on position. The battery connector under the seat is showing 52 volts and I've shorted the seat sensor so I don't to be in the seat. What are the next items I need to check? Thanks for all suggestions.
