Ryobi 725r fuel line routing
1947
I need to know the Ryobi 725r weed wacker fuel line routing. mine are broken off.
Ok I replaced the lines and routed per the video and replaced the leaking primer bulb. But when I try to prime it the bulb sticks in and won't pop back out. rechecked lines all good. removed carb and cleaned out with carb cleaner. retried and same thing sticks in. I can remove the lower line and it pops out but sticks again when retried. Any ideas?
Can you get me a picture of the carb with the fuel lines connected? I want to make sure you hooked everything up correctly. :thumbsup:
Oh I'm sorry, I saw the picture and was going to reply later but I forgot. :rolleyes::confused2:
It looks like the lines are connected properly, but I need a picture from the back of the trimmer to be sure. If they are attached correctly, your problem is either in the fuel filter or the carb.
